TractorLinks.com
Show Parts for Model:
Re: Compression Test
old
01-16-2013 14:50:31
You would probably be better of doing a leak down test instead of a compression test. By doing the leak down you would find which cylinder has the bad gasket area or crack in the head etc.
John in la
01-16-2013 20:07:47
 Re: Compression Test in reply to old, 01-16-2013 14:50:31
"You would probably be better of doing a leak down test instead of a compression test. By doing the leak down you would find which cylinder has the bad gasket area or crack in the head etc."
Maybe I am reading this wrong but it sure seems to me you are trying to say he should do a leak down test because a compression test will NOT show him what cylinder is bad.
"As for the bubbles in the radiator a leak down test would tell you which cylinder the bubbles come from so you then know where to better look for cracks"
There it is again. Use a leak down test to find the cylinder with the problem.
You do not really think a leak down test is any better than a compression test at pinpointing a problem in a cylinder and telling you what cylinder the problem is in. DO YOU???????????
old
01-16-2013 20:58:53
 Re: Compression Test in reply to John in la, 01-16-2013 20:07:47
Yes I do since a leak down test compresses air into each cylinder r one at a time so then you watch a gauge to see which cylinder will not hold compression over X number of minutes and in doing so you can watch the radiator for air/bubbles. As in you charge the cylinder up to X number of PSI and see where you loose the PSI and how fast
soundguy
01-16-2013 15:36:06
do both.. more tests the better..
old
01-16-2013 18:25:20
 Re: Compression Test in reply to soundguy, 01-16-2013 15:36:06
Very true plus with a leak down test you can maybe see bubbles in the cooling system that you may not see by doing the compression test.
