2000 offset fender
daverd4
Would it be possible for someone that has a 541 or 2000 offset to take a few close up pictures of the left rear fender can't find any on the net. Need to see how it is mounted to the tractor what kind of mount it has and if I can build one. The fender looks like a standard fender with what little I can see. With a part cut away for the rearend so I'm thinking I could build one If I had some good pic's to go off of.
Here's a couple pictures of mine it looks like it bolts to the top of the housing and that guard that is in front of it. Don't know if it's just a fender skin bolted on or if it has a mount?
THANK YOU!!! I think after seeing yours I can build one knowing where to cut the bottom with my plasma cutter. The support on the back looks like its the same width at top and bottom. Could you measure it for width and height so I can get it as close to factory as possible.Or does it look like they just cut the bottom off the regular fender or is it a fender skin with a custom built support welded on the back?
that support on back is a double lipped plate.. like a shallow C channel. not like a regualr fender bracket.
Thats what I thought. If it would be possible to get the measurments of it. I could have my local machine shop bend me one and just weld to a fender skin.I think thats the only way I'm going to get a left fender.
