Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 601 Parts Online
Re: ford 601 power steering
01-15-2013 17:39:54
OK guys, think I figured it out. Had to look at parts a couple of times and read repair manual again. The fellow I bought it from had run it a long time with no belt on pump, so no oil going thru control valve. Inside dried out and thrust bearings started to rust. Every time he drove tractor, it would grind on dry thrust bearing. The top bearing is completely gone, nothing left but a big flat washer. The bottom bearing doesn't look much better. Has also ruined needle bearings at top and bottom of shaft. I will get new parts, clean it all up, put back together and see what happens. Thanks.
