Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 601 Parts Online
Re: Ford 601
JMOR
01-15-2013 08:25:10
Quoting Removed, click Modern View to seeGauge at that point is OK, once you realize that the pressure is normal at as little as 40PSI and as high as 2000, depending on 3 point load & touch control command position. Better to remove plug & crank engine over to see if oil comes out. If not apply air compressor blow gun to hydraulic dipstick hole and see if you can make pump prime.
P.S. pump is driven off of a gear on rear of cam shaft, not off of flywheel.
Copyright © 1997-2015 Yesterday's Tractor Co.
