what manual
51hunter
New User
Im looking for a ford 3400 manual which will tell me all the fill plugs as well as drain plugs I have a FO-31 but it lacks this info.
You might find an owners manual for a 3400 but it could be a long search.
That tractor is identical to a 3000 ag model in all but the front axle. So you might check Ebay for a 3000 manual - either a reprint or an original. It will have all the info you are looking for.
i have a factory manual set of four books that is for the 2600, 3600,4100,4600,5600,6600,6700,7600,7700 issued in 08 1994 if that will help you i know its not specificly for the 3400 but if it will help you its here thanks, paul
Quick Google search found a digital version of the Operators manual for the 3400, 3500, 3550. 4400 and 4500 tractors available [u:481b764b90]HERE[/u:481b764b90]
I understand a fellow wanting the correct manual for his tractor.
But I think you will find that the info in a 2/3/4000 manual is significantly more applicable to your tractor than the one above.
