TractorLinks.com
Show Parts for Model:
what manual
51hunter
01-13-2013 08:09:04
Im looking for a ford 3400 manual which will tell me all the fill plugs as well as drain plugs I have a FO-31 but it lacks this info.
soundguy
01-14-2013 06:52:52
 Re: what manual in reply to 51hunter, 01-13-2013 08:09:04
should be the same as a 3000 for fill/drain.
51hunter
01-13-2013 15:11:36
 Re: what manual in reply to Sean in PA, 01-13-2013 12:21:20
Thanks for the info,at least now I know which one to look for
Ultradog MN
01-13-2013 16:43:34
 Re: what manual in reply to 51hunter, 01-13-2013 15:11:36
I understand a fellow wanting the correct manual for his tractor.
But I think you will find that the info in a 2/3/4000 manual is significantly more applicable to your tractor than the one above.
paul dahlgren
01-13-2013 09:07:23
i have a factory manual set of four books that is for the 2600, 3600,4100,4600,5600,6600,6700,7600,7700 issued in 08 1994 if that will help you i know its not specificly for the 3400 but if it will help you its here thanks, paul
Ultradog MN
01-13-2013 08:30:52
You might find an owners manual for a 3400 but it could be a long search.
That tractor is identical to a 3000 ag model in all but the front axle. So you might check Ebay for a 3000 manual - either a reprint or an original. It will have all the info you are looking for.
mhb@ufe
01-13-2013 08:15:34
You need an operators manual.
Mark
