TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 (diesel) Engine Block Viewing Window!
Brian Allen
01-13-2013 07:47:03
AV8R185
Do a very good inspection before you try to repair!
The hole is not your issue, it can be welded up very easily, the crank journals and caps are critical! The new cam will also need new bearings installed
If there are any main bearing caps broken or cracked, don't repair, at least that was what I was told regarding my 1979 4600 with a 201 Diesel with #1 rod doing the same thing. You can search, the pictures should be still in stuck and troubled.
Brian
