TractorLinks.com
Order Ford 800 Parts Online
Re: 800 ford 12volt conversion what altenator to use.
jmducks1
01-12-2013 18:52:11
working on 800 model. Well i bought the gm 3 wire. Mine has a 3 post starter solenoid. Is that good and do i have to switch the wires around on it or leave it? What is the reason for a fuse block terminal? Can i use the amp gauge? do i keep the regulator on and hooked up? How many wires do i have to add and where too? or do you have a diagram for me. Email please.
John in La
01-13-2013 06:39:56
 Re: 800 ford 12volt conversion what altenator to use. in reply to jmducks1, 01-12-2013 18:52:11
Your 3 post starter solenoid will work fine. A terminal block is just a place to hook wires together. The amp gauge or a bolt and nut wraped with tape will do.
Your old regulator and its wires go. Your alternator has a regulator built into it.
For a 800 with the 3 wire alternator you will need a one way diode from radio shack for the wiring.
You will also need a 12v to 6v resistor for the wire that goes to your old 6v coil. Most just replace the coil with a 12v version Napa part #IC14SB for less than $20 and then you do not need the resistor.
Here is a wiring diagram for you. Feel free to print it out and use it to help you with your tractor.
jmducks1
01-17-2013 19:47:53
 Re: 800 ford 12volt conversion what altenator to use. in reply to John in La, 01-13-2013 06:39:56
Another 800 ford question. I have a 3 post solenoid, do i take the small terminal wire off or connect it to the starter button? Which way should i wire it your way thats on you likes or your first one on yesterdays tractors?
JMOR
01-17-2013 20:37:54
 Re: 800 ford 12volt conversion what altenator to use. in reply to jmducks1, 01-17-2013 19:47:53
Quoting Removed, click Modern View to seeWithout the 3rd terminal of a 3 terminal solenoid connected, it will not do anything more than a walnut! What kind of question is that?! You are being confused by various post that are for other tractors. Some posters are less than helpful.
On an 800, the small solenoid terminal goes to the neutral safety start switch.
jmducks1
01-13-2013 06:44:09
Thanks alot i will try to figure this out today.
