Got the newly recored radiator put in today. Also recieved the power steering flange assembly back from forddoc to day. Thanks Adam, the parts look and work great. After putting new seals in the control valve and cylinder, I reinstalled everything and fired it up. Ran it around the barnyard for about 45 minutes and the cooling system works as it's intended as does the power steering with no leaks. So, those issues resolved for now. While waiting on parts figured I'd replace the proofmeter and ammeter. Ammeter works fine, but nothing on the proofmeter. When I took the old one out there was no drive cable inside the housing. Red flag right away. But the new one does nothing. Am I correct in thinking that the problem could simply be a broken drive inside the bushing on the hyd pump? Anyone had this before? Does it require pulling the pump or can those parts be accessed from the drive end of the pump? Or, am I completely off base here?
As always, thanks so much for your help.
