Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 960 Parts Online
Re: 960 overheat update
mhb@ufe
01-12-2013 17:32:12
The proof meter drive can be removed from the pump without removing the pump so it would be easy to take it out and check it.
Mark
Phil960
01-12-2013 17:41:34
 Re: 960 overheat update in reply to mhb@ufe, 01-12-2013 17:32:12
nice.....thanks Mark
mhb@ufe
01-12-2013 17:48:37
 Re: 960 overheat update in reply to Phil960, 01-12-2013 17:41:34
When you take it out make sure you check the bolt that holds the gear to the shaft. It should have a slot that the drive goes into. If someone put a standard bolt in there it won't work.
Mark
Phil960
01-12-2013 17:53:27
 Re: 960 overheat update in reply to mhb@ufe, 01-12-2013 17:48:37
Thanks Mark, I've been looking at the parts book and as much as the drive end moves back and forth, you might be right on. I'll probably try to get it apart tomorrow.
