TractorLinks.com
Order Ford 960 Parts Online
Re: 960 overheat update
Phil960
01-12-2013 17:07:51
Yeah, it's spinning. Seems like about quarter of an inch end play in that little drive thing laterally. If I push the cable in, I can get the cable so spin as well. Is the crimp on the cable too small, or the drive gear opened a little? Got me stumped. Seems like it won't stay engaged at the pump. Whatcha think?
soundguy
01-12-2013 17:13:04
 Re: 960 overheat update in reply to Phil960, 01-12-2013 17:07:51
by not engaged, is it slipping forward or spinning inside the bushing?
Phil960
01-12-2013 17:15:44
 Re: 960 overheat update in reply to soundguy, 01-12-2013 17:13:04
I can't be sure at this point, but I'd have to guess that it's slipping inside the bushing.
mhb@ufe
01-12-2013 17:32:12
 Re: 960 overheat update in reply to Phil960, 01-12-2013 17:15:44
The proof meter drive can be removed from the pump without removing the pump so it would be easy to take it out and check it.
Mark
Phil960
01-12-2013 17:41:34
 Re: 960 overheat update in reply to mhb@ufe, 01-12-2013 17:32:12
nice.....thanks Mark
mhb@ufe
01-12-2013 17:48:37
 Re: 960 overheat update in reply to Phil960, 01-12-2013 17:41:34
When you take it out make sure you check the bolt that holds the gear to the shaft. It should have a slot that the drive goes into. If someone put a standard bolt in there it won't work.
Mark
Phil960
01-12-2013 17:53:27
 Re: 960 overheat update in reply to mhb@ufe, 01-12-2013 17:48:37
Thanks Mark, I've been looking at the parts book and as much as the drive end moves back and forth, you might be right on. I'll probably try to get it apart tomorrow.
