Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 2000 Offset
mhb@ufe
01-12-2013 15:34:47
This is from John Smiths web site.
Decoding the 5 digit model numbers on 2000-4000 series tractors -
First number (1 digit)
2**** - 134 ci gasoline or 144 ci diesel engine
4**** - 172 ci gas, LP-gas or 172 ci diesel engine
Second number (1 digit)
*0*** - Industrial models produced prior to 1963
*1*** - Industrial and agricultural models produced after 1963
Third number (2 digits)
**10 * - Row crop
**11 * - Offset
**20 * - Utility-type w/adjustable front axle
**21 * - Orchard type w/ non-adjustable front axle
**30 * - Utility-type tractor w/non-adjustable front axle (light industrial)
**31 * - Low center of gravity (LCG tractor)
**40 * - Heavy duty industrial tractor w/sub frame **41 * - Heavy duty industrial tractor w/sub frame & cast grille Last number (1 digit) *1**0 - Four-speed w/o PTO *0**1 - Four-speed w/o PTO or hydraulics *1**1 - Four-speed w/PTO *0**2 - Four-speed w/hydraulics, w/o PTO *1**2 - Five-speed w/live PTO *0**3 - Four-speed w/hydraulics and PTO *0**4 - Select-O-Speed w/o hydraulics or PTO *1**4 - Select-O-Speed w/o PTO *0**5 - Select-O-Speed w/hydraulics and single-speed (540 rpm) PTO *0**6 - Select-O-Speed w/hydraulics, 540 and 1000 rpm PTO and ground-speed PTO *1**6 - Select-O-Speed w/two-speed (540 and 1000 rpm) independent PTO *1**7 - Select-O-Speed w/540 and 1000 rpm independent PTO and ground-speed PTO *0**9 - Five-speed w/live PTO Suffixes -1 - Tricycle with single front wheel -4 - High clearance with wide front -L - LP gas engine -D - Diesel engine Thousand Series tractor serial numbers - 1962 Serial number 1001 - 11947 1963 Serial number 11948 - 38930 1964 Serial number 38931 - up Part number identifiers cast into 134 and 172 engine blocks (lower right side) EAE 6015 - 134 1953-1957 EAF 6015 - 172 1953-1957 310905 - 134 1958-1959 310609 - 172 1958-1959 B9NN-6015C - 134 late 1959
Mark
Copyright © 1997-2015 Yesterday's Tractor Co.
