TractorLinks.com
Order Ford 6000 Parts Online
Re: Need Help: Brakes on Commander 6000
jake collie
01-11-2013 18:59:43
This site sells the ford service manual. The IT manual also is very good for the brake valve. I rebuilt my brake valve last year in about 3 hours start to finish. You start by relieving all hyd pressure from the system. Then unhook the hyd lines and unbolt the valve. Put it on the bench and disassemble. Keep the spools together with the bushings as they are closely matched to each other. It will be obvious where each o ring goes. There is no need to bleed the system when it is reinstalled. These brakes are considered self bleeding.
