Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 800 Parts Online
Re: 800 ford 12volt conversion what altenator to use.
old
01-11-2013 18:13:43
Reason I say use the plug is that in the past I have had problems with the spade terminals getting bent and that in turn shorts out the alternator and lets the smoke out
soundguy
01-11-2013 18:45:26
 Re: 800 ford 12volt conversion what altenator to use. in reply to old, 01-11-2013 18:13:43
you don't use the insulated female spade plugs? I do.. that's what they are for.. for sliding over male spades and then insulating them.
most GOOD wire terminal kits come witht he basic female spadesma nd the insulated female spades. I love em..
old
01-11-2013 18:58:54
 Re: 800 ford 12volt conversion what altenator to use. in reply to soundguy, 01-11-2013 18:45:26
Of course I also like the factory type plug since it ha the wires on them and that makes it easy to hook up as needed but the each there own
soundguy
01-11-2013 19:06:33
 Re: 800 ford 12volt conversion what altenator to use. in reply to old, 01-11-2013 18:58:54
i'm just not into buying a few dollar plug when i can make it for 10 cents of parts. I'm frugal. :) more money I save on useless 4$ parts.. the more tractors I can save up and buy. :)
old
01-11-2013 19:40:23
 Re: 800 ford 12volt conversion what altenator to use. in reply to soundguy, 01-11-2013 19:06:33
Ya most of the ones I do are for custamors (sp) or ones I plan to sell so I do it in such a way to look correct and easy to figure out
soundguy
01-12-2013 13:02:12
 Re: 800 ford 12volt conversion what altenator to use. in reply to old, 01-11-2013 19:40:23
look correct?
failed on that by hanging an alt on.. should be a generator. :)
easy to figure out?
2 wires? really?
old
01-12-2013 14:25:09
 Re: 800 ford 12volt conversion what altenator to use. in reply to soundguy, 01-12-2013 13:02:12
Ya easy most people I do the 12 volt conversions are those that see 2 wires remove them and then get them back wards and that is on a good day. When you have the show them what an oil bath air cleaner is and how to change the oil you know you have to do it so it is as we us to call it sailor proof
soundguy
01-12-2013 14:37:42
 Re: 800 ford 12volt conversion what altenator to use. in reply to old, 01-12-2013 14:25:09
i heard that.
I'm lucky if most people even add oil when low.. let alone change it!
old
01-12-2013 15:32:55
 Re: 800 ford 12volt conversion what altenator to use. in reply to soundguy, 01-12-2013 14:37:42
Ya know what you mean there. I still say a person to be able to have a drivers license should have to show the tester how to check the oil the radiator the brake fluid and also be able to change a tire in a safe manner. Ya the tire could maybe be lot go if they had triple A or some such thing but even then maybe not
