Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Where do I put in the hydraulic oil?
Larry NCKS
01-11-2013 14:57:12
Let me see if I can do better. Many industrial tractors are set up to run loaders and backhoes that are powered by means of an auxiliary pump. This pump is often attached to the front of the engine and is driven by the crankshaft. If this is the type of system you're inquiring about, then there will a reservoir other than that contained within the housing of the tractor, often part of the loader frame. I do not know specs on the oil for this type of system.
A normal ag tractor with a 3 point hitch will hold its hydraulic in the center housing. This is the cavity between the transmission and rear axle. This type of system requires a Tractor Fluid or Hydraulic Fluid that meets or exceeds the New Holland Spec M2C-134-D. It is not an ATF (automatic transmission fluid).
RodInNS
01-11-2013 15:14:00
 Re: Where do I put in the hydraulic oil? in reply to Larry NCKS, 01-11-2013 14:57:12
He could actually use ISO 46 in an isolated hydraulic compartment like that one where it's not acting as a gear lubricant... Again, I say could. If it was mine I'd still use TDH/134D for the sake of simplicity as the cost is about the same...
Rod
Dave314
01-12-2013 11:21:38
 Re: Where do I put in the hydraulic oil? in reply to RodInNS, 01-11-2013 15:14:00
I bought 5 gallons of the 134D at Walmart. I removed the plug under the seat and put about a gallon of it in there. I started the tractor and moved the two levers that control the bucket. One lever made the bucket go up when I moved it both forward and back. I couldn't get it to go down. The other lever didn't tilt it up and down like it's supposed to. It didn't do anything at all. Next I removed the two hoses and switched them because I thought maybe they were on backwards, but the same thing happened. One lever makes the bucket go up when it's moved in either direction and the other lever doesn't do anything. Any idea what the problem is now? I'm only interested in hearing from guys who can make positive comments. Thanks....
Dave in MS
01-13-2013 12:30:45
 Re: Where do I put in the hydraulic oil? in reply to Dave314, 01-12-2013 11:21:38
Look between the radiator and the crank pulley on the front of the engine. If there is something in that space attached to the crank pulley, and it has hydraulic hoses attached, you are looking at the auxillary hydraulic pump that your loader uses to operate it's cylinders. If there is nothing attached to the crank pulley, then more than likely the loader runs off the tractor's built in hydraulic system. Tell us what you see, and as previously mentioned, take pics and post them here if you can. We will be better able to give you some guidance if you give us as much info as possible.
You have been given some good advice. Some replies were a touch on the hot side, but even though you are frustrated and want to get your machine fixed right now, attempting to hide behind an alternate handle for the purpose of getting back at someone, shows that you not only know little about tractors, but also, little about IP addresses.
Larry NCKS
01-12-2013 11:51:05
What was the level of the oil on the dipstick after you added the gallon?
Are the boom cylinders single acting or double? If they're single you'll need to add fluid until it's on the full mark all cylinders extended with the boom all the way up.
Sounds like you've still got hoses screwed up to me, as well as not enough oil yet. Did you take one end of the hoses off and crisscross the connections, or did you take the hoses off completely and swap them?
You need to learn to speak in more sophisticated terms to get the most out of the help we have to give.
Oil
01-12-2013 15:41:49
 Re: Where do I put in the hydraulic oil? in reply to Larry NCKS, 01-12-2013 11:51:05
More sophisticated terms? What kind of an assinine comment is that? What are you, some kind of a drama queen? This is a tractor website, not one for nuclear physics. I'll go somewhere else to ask my questions. Grow up, a$$hole....
Oaf
01-13-2013 17:22:03
 Re: Where do I put in the hydraulic oil? in reply to Oil, 01-12-2013 15:41:49
Whoa, that turned in a hurry.
Sean in PA
01-12-2013 17:50:50
Oil said: (quoted from post at 19:41:49 01/12/13) More sophisticated terms? What kind of an assinine comment is
my questions. Grow up, a$$hole....[/quote:eba3c96131]
oil??? Are you the same person (Dave314) that asked the original questions? Why did you change your handle from Dave 314 to oil? That's just adding to the confusion if you did. If you (oil) are not the same person as the original Dave314, then stop posting as if you are.
Now Dave314 posted this:
[quote:eba3c96131]Next I removed the two hoses and switched them because I thought maybe they were on backwards
This is what Larry was asking you to be more clear about. Correct routing of hydraulic fluid in a loader is a very exacting thing, so you need to be more clear how you describe what changes you made.
Your statement about switching the 2 hoses appears to mean that you removed both ends of both hoses and just swap the positions of the 2 hoses, which will not actually change anything about the way the fluid flows. Did you mean to say that you disconnected one end of each hose and swapped their positions? This would make more sense as this would reverse the flow from the original configuration.
So let's get a more detailed description of your loader setup.
Do you have 2 hydraulic cylinders, one on each side, that provide the lift for the arms, or just 1? These are called the lift cylinders. If the loader has arms on both sides, they generally have 2 lift cylinders, but there are "one armed" loaders that only have a single lift cylinder.
Do the lift cylinders each have 2 hydraulic lines going to them, or just 1 hydraulic line each? If there are 2 lines going to each cylinder, then they are double acting, meaning that the hydraulics provides power to both lift and lower the arms. If they only have one line going to them, then that is called single acting, and the hydraulics only provide power to lift the arms, while gravity provides the power to lower the arms. Whether you have single or double acting cylinders will help us to try to figure out what is going wrong, as we are not there in person and we can only guess what's going on if we don't have the full picture..
Do you have 1 or 2 (or possibly none) hydraulic cylinders that control the curling/dumping of the bucket? These are called the bucket cylinders. If it has none, and instead uses a manual cable or lever to dump the bucket, then that's called a trip bucket.
Do the bucket cylinders have 1 or 2 hydraulic lines going to each one? (that is if your loader actually has any bucket cylinders)
Also, we still don't know if the loader is being run off the tractor's internal hydraulics or if it has a separate front mounted pump with a separate reservoir. If you don't know, could you please provide some pictures so that we can try to determine this for you?
Please answer these questions as clearly as you can and then we will probably have more questions once we know exactly what kind of loader setup you have. Your answer doesn't have to be "sophisticated", just clearly stated so that nothing is ambiguous or left for us to guess at.
This post was edited by Sean in PA at 18:12:55 01/12/13.
Larry NCKS
01-12-2013 18:04:12
 Re: Where do I put in the hydraulic oil? in reply to Sean in PA, 01-12-2013 17:50:50
Sean in PA said: (quoted from post at 20:50:50 01/12/13)[/quote:bbe38700f2]
[quote:bbe38700f2]oil??? Are you the same person (Dave314) that asked the original questions? Why did you change your handle from Dave 314 to oil? That's just adding to the confusion if you did. If you (oil) are not the same person as the original Dave314, then stop posting as if you are.
Great catch Sean. I'm on modern view which doesn't show that IP address. Once I switched to classic there it is.
I guess it's alright for him to tell me I need "to put things in English", but when I ask him to be more clear about things, I get that kind of reply. To top that off he's brave enough to try to hide behind some other identity????
It's OK! I'll quit trying to help him now! I don't have any tolerance for such treatment, especially from someone I'm trying to help.
This post was edited by Larry NCKS at 18:15:57 01/12/13 2 times.
Copyright © 1997-2015 Yesterday's Tractor Co.
