Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: No drive
Sean in PA
01-11-2013 12:22:16
Did you check the traction disconnect?
fire/farm
01-11-2013 12:29:44
 Re: No drive in reply to Sean in PA, 01-11-2013 12:22:16
Yes I did. The trans is locked up but no drive.
Larry NCKS
01-11-2013 12:51:27
 Re: No drive in reply to fire/farm, 01-11-2013 12:29:44
Most likely cause is failure of the TLC (torque limiting clutch) This unit is in the tractor's flywheel so is a front split. It could be that the clutch hub itself broke loose or it could be that the splines on the input shaft and/or clutch hub wore out.
Check to see if your PTO will function at all. If not the above scenario is a very sure bet.
