Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: No drive
[Return to Forum]
fire/farm
01-11-2013 12:00:47
24.124.20.43
I have no drive at all in and gear. I was blading the driveway and suddenly the power to the rear wheels was lost. I can shift through all gears and none works. It seems like it wants to go in r2, 3, and 4, but won"t. The fluid is full and fairly clean. What can I do?
[Reply]   [No Email]
reb-in-pa
01-12-2013 14:07:41
75.206.3.251
 Re: No drive in reply to fire/farm, 01-11-2013 12:00:47
Guys -- I've only had one SOS apart (and it didn't survive the operation), but wouldn't intermittent failure of the pump in the trannie act like this? What if something occasionally blocked the pickup/intake for the pump?
[Reply]  [No Email]
fire/farm
01-11-2013 17:40:25
24.124.20.43
It actually started working again. It has done that before and it started working again after it sat awhile. It also seemed to help when I raised/lowered the pto. This time it sat for 2 days and this mornin it still didn"t work the first try. I read the manual for a while and tried it again. That time I throttled it up full and put it in 1. It didn"t go immediately but finally slid into gear. I still don"t know what went on.
[Reply]  [No Email]
Sean in PA
01-12-2013 05:02:08
71.224.102.32
 Re: No drive in reply to fire/farm, 01-11-2013 17:40:25
The PTO does not raise and lower. Do you mean raise/lower the 3 point lift? or engage/disengage the PTO?
[Reply]  [No Email]
Larry NCKS
01-11-2013 18:22:07
70.195.1.127
Raised/lowered the PTO ????????
That lets the TLC out. Sounds more now like a sticky valve in the control valve body or a leak that gets more exaggerated as the unit warms up.
[Reply]  [No Email]
fire/farm
01-11-2013 18:30:08
24.124.20.43
 Re: No drive in reply to Larry NCKS, 01-11-2013 18:22:07
That"s what I was thinkin. I was also considering
the overrunning clutch or sticking bands.
[Reply]  [No Email]
Dean
01-11-2013 18:15:55
152.216.3.5
It's not fixed.
Problems will return.
Dean
[Reply]  [No Email]
Dean
01-11-2013 12:50:38
152.216.3.5
Does the PTO work properly?
Dean
[Reply]  [No Email]
Sean in PA
01-11-2013 12:22:16
71.224.102.32
Did you check the traction disconnect?
[Reply]  [No Email]
fire/farm
01-11-2013 12:29:44
24.124.20.43
 Re: No drive in reply to Sean in PA, 01-11-2013 12:22:16
Yes I did. The trans is locked up but no drive.
[Reply]  [No Email]
Larry NCKS
01-11-2013 12:51:27
70.195.0.111
 Re: No drive in reply to fire/farm, 01-11-2013 12:29:44
Most likely cause is failure of the TLC (torque limiting clutch) This unit is in the tractor's flywheel so is a front split. It could be that the clutch hub itself broke loose or it could be that the splines on the input shaft and/or clutch hub wore out.
Check to see if your PTO will function at all. If not the above scenario is a very sure bet.
[Reply]  [No Email]
fire/farm
01-11-2013 12:07:58
24.124.20.43
Sorry forgot to mention its a 59" 881.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
