Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 851 hydraulic issue/draft control
JMOR
01-11-2013 08:25:00
Quoting Removed, click Modern View to seeLinkage wear/adjustments wrong/etc. It is no wonder at all that you would not understand why pressure on draft/posn lever will result in raising, where otherwise it won't raise, as it takes some real study/observation/understanding of the linkages to see this cause/result. It is primarily related to the wear/adjustment problem noted and is an abnormal input to the control arm when you apply this pressure. About the most you can glean from it is that linkage is worn to point of being out of adjustment.
