| Ford Tractors Discussion Forum |
Topic: Re: 800 ford 12volt conversion what altenator to use.
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| John in La
01-11-2013 03:30:31
184.38.239.35
| jmducks1
01-16-2013 18:42:21
69.129.14.114
Re: 800 ford 12volt conversion what altenator to use. in reply to John in La, 01-11-2013 03:30:31
| Another question about my 800. It has a 3 post solenoid do i keep the small terminal wire off or do i hook it up to starter push button? Which diagram should i use the one on your likes 2nd one or the one on yesterdays tractors? |
| jmducks1
01-12-2013 18:52:11
69.129.14.114
| working on 800 model. Well i bought the gm 3 wire. Mine has a 3 post starter solenoid. Is that good and do i have to switch the wires around on it or leave it? What is the reason for a fuse block terminal? Can i use the amp gauge? do i keep the regulator on and hooked up? How many wires do i have to add and where too? or do you have a diagram for me. Email please. |
| John in La
01-13-2013 06:39:56
184.38.174.254
Re: 800 ford 12volt conversion what altenator to use. in reply to jmducks1, 01-12-2013 18:52:11
| Your 3 post starter solenoid will work fine. A terminal block is just a place to hook wires together. The amp gauge or a bolt and nut wraped with tape will do.Your old regulator and its wires go. Your alternator has a regulator built into it. For a 800 with the 3 wire alternator you will need a one way diode from radio shack for the wiring. You will also need a 12v to 6v resistor for the wire that goes to your old 6v coil. Most just replace the coil with a 12v version Napa part #IC14SB for less than $20 and then you do not need the resistor. Here is a wiring diagram for you. Feel free to print it out and use it to help you with your tractor.
| jmducks1
01-17-2013 19:47:53
69.129.14.114
Re: 800 ford 12volt conversion what altenator to use. in reply to John in La, 01-13-2013 06:39:56
| Another 800 ford question. I have a 3 post solenoid, do i take the small terminal wire off or connect it to the starter button? Which way should i wire it your way thats on you likes or your first one on yesterdays tractors? |
| JMOR
01-17-2013 20:37:54
72.181.173.171
Re: 800 ford 12volt conversion what altenator to use. in reply to jmducks1, 01-17-2013 19:47:53
| Quoting Removed, click Modern View to seeWithout the 3rd terminal of a 3 terminal solenoid connected, it will not do anything more than a walnut! What kind of question is that?! You are being confused by various post that are for other tractors. Some posters are less than helpful.
On an 800, the small solenoid terminal goes to the neutral safety start switch. |
| jmducks1
01-13-2013 06:44:09
69.129.14.114
| Thanks alot i will try to figure this out today. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
