Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 800 Parts Online
Re: 800 ford 12volt conversion what altenator to use.
01-10-2013 20:41:00
First off any alternator in the 60s and early 70s used an external V.R which you do not want. The ones on like I said a 1980 Chev pick up had the internal V.R which you do want. The 2 wire plug has markings of #1 and #2. The #2 goes to the bog stud on the alternator and what it is is the sensing wire for the VR which tells the alternator VR when to shut off. The #1 wire is how a person turns the excite circuit on. But you need the diode I told you about or the alternator can/will back feed the ignition so you can not shut the engine off
