Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 900 distibutor grounding out
old
01-10-2013 09:18:50
Could be a number of problems. First tell us what you have done to it so maybe we know what you did not install correctly if you installed in new parts.
That said pull the wire off the points and see if the short goes away. If it does either the points are bad or you have the condenser wire or other such thing grounding. If it is still grounding out with that wire pulled then the insulator going threw the side of the distributor could be bad. My 841 had that problem and has a wire in place if the insulator. By the way do these test with the point open not close. Also make sure the point are in fact opening and closing as they should because it they do not open then you will have a short cause by them not opening
Copyright © 1997-2015 Yesterday's Tractor Co.
