Ford 2110 gas 3 cylinder industrial
marNY
New User
trying to get this tractor running again, would anyone have the plug information and firing pattern for this tractor? Thank you
2110 should be the Low Center of Gravity version of the 1965-1975 3 cylinder 2000. Firing order should be 1-3-2, and the original spark plugs were Autolite AG5, which you can cross reference to a number of other brands, but most folks swear by the Autolites. Plug gap should be 0.025.
Shouldn't the firing order be 1-2-3? That's what it is on my 4600 diesel. I know - bigger, newer model, but pretty sure all the 3-cyl's were the same firing order.
Mark, you are correct.
It's 123.
On a gasser it's cast right into the manifold.
PS, distributer turns CCW
