| Ford Tractors Discussion Forum |
Topic: Re: Can't lower lift arms on my 801
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| PhilC
01-08-2013 06:56:11
75.121.160.18
Correct Larry. Actually, I never moved the draft/position lever, it's still in position mode. Apologies to old, I should have been clearer in my earlier reply. :oops:
I didn't think about the draft/position lever until I read old's post, but I had already parked the tractor by then and was back indoors. I did move the lift control lever up and down several times while I was using the FEL, but it didn't make any difference. I left the lift control lever in the down position when I put the tractor away about 11:30. At 4pm, I decided to take a look when I was tossing a tennis ball for my yellow lab, and lo and behold, the arms were down.
Now, this brings up a new question. Is it better to leave the lift arms down, mid-way, or up when the tractor is parked? If the arms got stuck while up would they also get stuck when down? I park it in my shop, and cannot get through the 8' door with the back blade (also 8') attached, so it's always put away without an implement. I have been parking it with the arms up, but this discussion now has me wondering if full down is the better option.
Sure appreciate the replies. When warm, dry weather returns to eastern WA, I'll pull the topdeck and give it thorough cleaning, don't suppose it will hurt a thing to do that. Maybe I'll fix my power steering (separate and much more involved issue) while I'm at it. :wink: |
| old
01-08-2013 09:08:57
209.86.226.18
Re: Can't lower lift arms on my 801 in reply to PhilC, 01-08-2013 06:56:11
| Well on my 841 with loader that is parked out side I when I park it set a wood block under the back blade which has 6-85lbs suit case weights and a 150lbs wheel weight on the center link area. I also set a wood block under the bucket. That way neither on sits on the ground so as to keep it from freezing down. More or less a safety device since years ago I had one start up and the 3 point control was set to go up and the tractor did a wheelie due the the back blade being frozen to the ground. Not the best way to start the day |
| JMOR
01-08-2013 07:04:58
72.181.173.171
| Quoting Removed, click Modern View to seeMind you, strictly an opinion, but I prefer to park with everything hydraulic in a pressure relieved state. In the case of your lift, that means down. Reason being that in a spool valve, pressures keep it forced up against the bushing & I would rather that it sit there floating freely. And it is a spool valve that controls the flow to dump the cylinder & lower it. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
