| Ford Tractors Discussion Forum |
Topic: 4600 - two questions
[Return to Forum]
| Author |
[Modern View]
| Ultradog MN
01-07-2013 13:04:00
184.100.109.75
First, where you you check the oil level in the rear end? Second, got a brake seal leaking. Do we have to pull the trumpets to renew or can they be done from the outside? Ken says thanks. |
| Ultradog MN
01-09-2013 02:14:42
184.100.109.75
Re: 4600 - two questions in reply to Ultradog MN, 01-07-2013 13:04:00
| Thanks guys. I ordered the seals for the brakes yesterday but still haven't found the check plug. Will look some more. |
| RodInNS
01-07-2013 19:07:21
216.118.158.123
| | Level plug should be in the housing, on the right side, about the level of the footboard or slightly above... to the rear. The brake boot... strip the linkage off the rod, then use a sharp cold chisel to free the metal backer of the boot from the axle housing. When installing the new one I usually remove the spring, slide it all the way up the rod until it seats, then use a piece of pipe or some such drift over the rod to get the backer seated into the housing. Then you reinstall the spring. You can either drain some oil off before you start this job or run that side up on a couple of blocks to chase the oil to the other side... Rod |
| mhb@ufe
01-07-2013 16:01:30
184.153.187.144
| | If it is the seal where the brake rod goes into the housing you don't need to pull the trumpet. Just unhook the linkage, remove the adjusting nut and pop the seal out and install the new one. Mark |
| Fordfarmer
01-07-2013 15:49:17
184.158.37.11
| Rear end oil is checked at a level plug by your right heel... not -quite- where the picture in the book shows it. (I think they used a picture of a 4000, but the location was slightly changed on the 4600) If no one else chimes in with a better description of where it is, I'll try to remember to bring in my manual after chores. Brake seal... the boot where the actuator rod goes in, or the seal at the end of the axle? Never done either myself, but I've read here that replacing the boot is pretty straight forward, and does not require removing the trumpet. |
| soundguy
01-08-2013 05:48:45
184.246.206.123
Re: 4600 - two questions in reply to Fordfarmer, 01-07-2013 15:49:17
| yep.. the check on the 4600 is higher than the 4000. took me forever to find mine as it was an inverted head plug screwed in flush and had 40ys of dirt caled on the side.. :) |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
