TractorLinks.com
Order Ford 3400 Parts Online
Re: 3400 gas motor
Ultradog MN
01-07-2013 03:12:18
Andy,
That engine was not sleeved from the factory.
So it had to be sleeved when it was rebuilt which is a good sign that they did it right.
Sleeves are available both OEM and aftermarket so it was probably up to the rebuilder where they bought them from.
Fun dropping the pan on that tractor isn't it?
You pretty much have to pull the whole front end off the tractor because of the pan to bolster bolts. Much easier to do on it's ag sister the 3000 with the steel pan.
RodInNS
01-07-2013 07:23:21
 Re: 3400 gas motor in reply to Ultradog MN, 01-07-2013 03:12:18
Some were sleeved from the factory... Basically, if they had a block that didn't machine true and clean the first time around they'd overbore and sleeve to clean it up rather than throw it back into the melting pot...
IIRC, those engines were denoted by a diamond in front of the engine serial number.
Rod
Ultradog MN
01-07-2013 07:38:17
 Re: 3400 gas motor in reply to RodInNS, 01-07-2013 07:23:21
I did not know thst.
Having it already sleeved would sure make a rebuild cheaper when it came to needing it.
RodInNS
01-07-2013 11:18:13
 Re: 3400 gas motor in reply to Ultradog MN, 01-07-2013 07:38:17
Not necessarly... as stated, these were repair sleeves, done as necessary. You'd still need a machine shop to fit another repair sleeve. It's not like the hundred series that used a dry sleeve and they were all bored and fitted the same way...
Rod
