Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Multiple Block Heater Failures-Ford 5000
[Return to Forum]
swinetime
01-06-2013 18:09:21
69.19.14.24
Purchased and installed after market threaded block heater fall of 2010. After using twice it quit working. Bought another one about 2 weeks ago and it failed on second time used.
Element can't be touching metal.
Would I do any better buying an original equipment element. You'all think there would be that much difference. Or what am I doing wrong.
Help
Swinetime
[Reply]   [No Email]
swinetime
01-09-2013 18:24:47
69.19.14.35
Re: Multiple Block Heater Failures-Ford 5000 in reply to swinetime, 01-06-2013 18:09:21
Robert Major, the block heater on my tractor is located more towards the front, probably 2 to 2 1/2 feet forward from the starter. Loader on tractor- gets in the way pretty bad-and can't really use any sockets but it's not impossible. Been where you described before though. One of those 30 minute jobs that turns into 4 hours. If the weather is cold extreme you can pretty well multiply by 4. Forgot to mention, if I attempt to change out block heater one more time, and do it this weekend Saturday temp supposed to be...........................70F..............that's no lie-----here in southern Ohio.
Swinetime
This post was edited by swinetime at 18:28:52 01/09/13.
  [Reply]  [No Email]
Jerry/MT
01-07-2013 09:57:31
206.183.116.145
Make sure the block heater is UNPLUGGED BEFORE YOU START THE ENGINE!
Without going into all the fluid mechanics and heat transfer, having the element plugged in with the engine running can cause it to overheat and fail.
Most intsallation instruction warn you about this.
  [Reply]  [No Email]
Billy NY
01-07-2013 08:55:12
72.226.79.200
I went through 3 of those on the 3600, well the one that goes in the radiator hose. I had it on a timer, but I think it was like 600 watts, too, it did work great, but they never last the winter, the darned thing started easily when it was on a few hours before. I could not figure out what the deal was, coolant was changed, and up, thermostat working, I put cardboard in front of the radiator, and spread a couple of loads of manure, made sure to get it nice and hot, before plugging it in for the first time.
  [Reply]  [No Email]
Greg_Ky
01-07-2013 07:54:47
216.146.234.53
I read somewhere a few years ago, I think it was in my repair
manual for my 655A TLB ( same motor as 5000) it takes a 700
watt heater, to large of heater would boil the water and creat
an air pocket and premature failure of the heater. Hope this
helps.
  [Reply]  [No Email]
RodInNS
01-07-2013 07:12:04
216.118.158.123
I would say you probably had an air pocket around the element that cause it to overheat and open circuit.
When you change them... make sure you refill with coolant, run the engine until it's warm and burped.
I'm not a big fan of cheat aftermarket heaters.... but I've seen the OEM ones burn out the same way... so that's not necessarly insurance.
Rod
  [Reply]  [No Email]
Brian Allen
01-07-2013 05:17:27
74.198.87.65
swinetime
I would run the tractor at least enough to bring it to operating temperature before trying to use a new heater.
One thing I try to do on my tractors is to drill a small hole (1/8") in the thermostat plate when installing. This prevents air locking in the system, which is what burns out the heating elements, and also, overheats the motor until the air is all purged.
Brian
  [Reply]  [No Email]
swinetime
01-07-2013 04:33:54
69.19.14.24
Showcrop, we did loose some liquid. We had the new one ready to go with pipe tape on it and as soon as we pulled the old one out stuck the new one in. I'd guess we probably lost 4 to 8 ounces of liquid. Before plugging in new heater we topped the radiator off with antifreeze. I'm beginning to think that because we did not start the tractor and let the thermostat open up we had an air pocket. But, after installing and adding antifreeze we did plug in block heater and it for sure worked for at least 3 hours as we did some other maintenance on tractor. In my original post I noted that it worked a second time but I'm really not sure of that because son plugged it in AM and when I got home that evening the block was cold and no heat at all on plug or anywhere else. I probably wrongly assumed that it worked the second time. I'm really beginning to think that there wasn't enough liquid on the electrodes the first time and it shorted out then. On the other hand it seems impossible that the amount of liquid that came out of the hole while changing heaters could cause air pocket. I may try it one more time.
Sure appreciate everybody's help.
Swinetime
  [Reply]  [No Email]
Sean in PA
01-07-2013 04:58:45
71.224.102.32
Re: Multiple Block Heater Failures-Ford 5000 in reply to swinetime, 01-07-2013 04:33:54
I'm not that familiar with engine block heaters, but if it's anything like a heating element in an electric hot water heater, then not having the heating element submerged in liquid will not cause it to short out. It will cause it to burn itself up and cause an "open circuit". Sometimes it will be visibly burnt up, but other times it will look perfectly fine but just won't work.
Only a few ounces of liquid coming out when you pulled the old one out sounds like something's pretty clogged up to me. All of the coolant in the engine from the level of the plug hole up to the top radiator hose should have tried to come out.
  [Reply]  [No Email]
Ed1
01-07-2013 03:57:29
72.152.126.151
I have a block heater (freeze plug) on my 5000D and it works
perfect for about 8 years now. Don't know the brand , it was on
the tractor when I bought it. I don't leave it plugged in
overnight, just use it when I need it. It takes about 2 hrs. To
heat it up in 20 degree weather. That's about all I can tell you.
Ed1
  [Reply]  [No Email]
swinetime
01-07-2013 03:22:02
69.19.14.24
The element screwed into the same whole as original equipment-into block towards the front. I've not yet removed the newest failed heater, but the first one which I just removed a little over a week ago, the element was not burnt at all, shiny as the day I put it in a year ago.
Maybe had an air pocket. I can start the tractor without the heat as long as it's not too cold. What I would like to do is install new heater and make sure there are no air pockets before plugging in. How can I be sure no air pockets?
Swinetime
  [Reply]  [No Email]
showcrop
01-07-2013 03:54:07
75.67.231.80
Re: Multiple Block Heater Failures-Ford 5000 in reply to swinetime, 01-07-2013 03:22:02
I can't see how you could have an air pocket unless you have a tremendous sludge build-up. If you remove the one that is in there now, without lowering the coolant level, and no coolant comes out, I would say that you need to do some cleaning.
  [Reply]  [No Email]
oldtanker
01-06-2013 20:31:03
66.228.255.239
Are you talking about the type that goes into the water jacket? If so several "rules" have to be follower. The element cannot touch metal. You cannot plug it in until you are certain that the element is completely submerged in coolant. What does the element look like when it's burnt up?
What brand? I've had great luck with Kats brand freeze plug heaters. Never had one go bad.'
Rick
  [Reply]  [No Email]
Retired Farmer
01-07-2013 00:28:36
207.200.116.132
Re: Multiple Block Heater Failures-Ford 5000 in reply to oldtanker, 01-06-2013 20:31:03
I just had one of those freeze plug heaters burn up in the Versatile night before last. Don't even want to think about replacing it. Stupid Cummins engineers put it behind a big tube on the side of the engine.
  [Reply]  [No Email]
Robert major
01-09-2013 16:53:03
216.81.5.153
Re: Multiple Block Heater Failures-Ford 5000 in reply to Retired Farmer, 01-07-2013 00:28:36
Must be related to the engineers that put the one in the 466 inter motor in a 5088, I changed the other day for a customer, in 40oc below with wind chill and not wearing gloves half the time!.
I needed a 1/4" more to get the heater out as it hit the starter, had to half remove the starter to get the space. The guy that designed that never talked to the guy that made the bolts to hold the starter,or the guy that designed the tractor frame rails, Had to use a 3/8 drive 12 point socket to fit the bolt heads as the 1/2" socket would not fit in the lug gap. Then had to use 18"+ of 1/2 drive extensions and a universal joint/ adapted down to 3/8 and a 3 ft knuckle bar to get enough torque to slacken the bolts then had to loosen them the rest of the way with my fingers.
good luck with yours
Regards Robert
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
