Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: '62 Ford 2000 Throttle Linkage
[Return to Forum]
tigercreek
01-06-2013 10:11:40
74.171.79.247
Long story short, I can't adjust the throttle linkage out on my tractor. I managed to break one linkage and the spare I have will do the same if I force it.
Is there a way to replace the linkage rod and the clevis? I have found the rods for sale but the clevis does not come with it. Maybe someone has come up with a creative way to remedy a similar situation.
I have furnished a picture of the broken rod and the good one that is too short. I have drilled out the broken rod from the broken clevis in case I have to tap it for a new rod.
[Reply]   [No Email]
tigercreek
01-11-2013 15:53:22
74.171.79.247
 Re: '62 Ford 2000 Throttle Linkage in reply to tigercreek, 01-06-2013 10:11:40
Well I "repaired" the old linkage. I drilled out the clevis, inserted a 2" 10-24 bolt and attached a turnbuckle nut. I then cut off an inch of the old rod and and threaded it for a 10-24.
It works :-)
[Reply]  [No Email]
soundguy
01-07-2013 07:10:28
173.105.56.219
just make new ones.
BTDT with them rods.. clutch and brake linkage.
you can make a clevis with scrap and nuts if you have to.. and low current welder, solder or braze.
soundguy
[Reply]  [No Email]
tigercreek
01-06-2013 11:57:24
74.171.79.247
Yes, I have backed off the lock nut.
I've tried a torch and penetrating oil. The problem is that the rod starts twisting at the threads before any of the torque gets to the clevis. I'm afraid that if I try any more I will have two broken rods. I guess the rods are just old and weak enough that they are going to give before the clevis.
[Reply]  [No Email]
Forddoc
01-06-2013 10:59:32
184.97.47.82
Wire brush all visible threads, even between clevis arms, soak
with penetrant, clamp clevis arms in vise break your nut loose
back it off, then clamp the rod in the vise length ways so you
can see the threads between the clevis arms and turn clevis
back and forth easy with a crescent wrench, while adding
more penetrant. If it don't budge apply heat to the clevis body.
If you don't have a torch there has to be someone or shop
around that does. You're not the first that this has happened
to, but they are a lot easier to get loose in a vice than on the
tractor and easier to see.
[Reply]  [No Email]
showcrop
01-06-2013 10:46:44
75.67.231.80
Did you loosen the lock nut?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
