Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 3000 Parts Online
Re: Ford 3000 radiator HELP!
sixbales
01-05-2013 13:15:16
That small hose is an overflow tube for the radiator. Ford radiators will typically release coolant until the fluid level is down just above the core. And they work fine after the equilibrium level is achieved. And there"s no point to topping it up again, as it will waste coolant.
The tube doesn"t normally blow off. Your overflow tube may be plugged. Check it out.
Mr Manouche
01-05-2013 13:33:59
 Re: Ford 3000 radiator HELP! in reply to sixbales, 01-05-2013 13:15:16
Thanks sixbales. I pulled the top of the overflow tube off and blew as hard as I could thru it. I can't tell if it was plugged but if it was, its not anymore. My operator's manual said that if the fluid level is more than an inch below the bottom of the filler neck to add more fluid. I topped it off b/c I looked in there and didn't see any fluid. Could that be b/c equilibrium was achieved? Should I drain a little fluid out before starting it up again? Also, where does the bottom of the overflow tube connect?
soundguy
01-05-2013 14:09:30
 Re: Ford 3000 radiator HELP! in reply to Mr Manouche, 01-05-2013 13:33:59
if you add fluid.. it will just blow more out till it is happy.
bottom of tube connects to atmosphere...
sixbales
01-05-2013 14:00:52
You should be able to see fluid above the core when equilibrium is reached. If it is below the top of the core, you've got a leak.
soundguy
01-05-2013 14:27:57
 Re: Ford 3000 radiator HELP! in reply to sixbales, 01-05-2013 14:00:52
i just butchered your handle in a post a few minutes ago.. apparently can't edit it. sorry ;)
sixbales
01-05-2013 14:59:31
 Re: Ford 3000 radiator HELP! in reply to soundguy, 01-05-2013 14:27:57
No problem Chris, I got a kick out of it !!
sixbales
01-05-2013 14:00:21
Mr Manouche
01-05-2013 14:11:34
 Re: Ford 3000 radiator HELP! in reply to sixbales, 01-05-2013 14:00:21
Got it. THanks sixbales and soundguy. Im gona keep an eye out for a used radiator that dont leak. Appreciate yalls input. This website is the best.
