Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: '55 650 exhaust manifold
01-04-2013 15:24:30
spacer plate or slots. both work.
good luck!
01-04-2013 20:04:58
 Re: '55 650 exhaust manifold in reply to soundguy, 01-04-2013 15:24:30
You"re right as usual soundguy. There is enough meat there to cut away to slip the nuts on, but the spacer idea doesn"t really have enough room without increasing the slots outward. Otherwise the studs to the manifold would interfere with the screws to the carb. I don"t have anything trustworthy to cut the manifold so off to the machinist they go.
It"s never as easy as you want it to be. Such is life!
01-05-2013 13:19:39
 Re: '55 650 exhaust manifold in reply to Oaf, 01-04-2013 20:04:58
that manifold cuts remarkably easy. a flat file will square outr some area for nuts.. and a rat tail will make slots.
a die grinder stone or bur will too. that grey iron is super soft.
one of those drill bits with the 'teeth' onthe side will do it.. that's wht I did the one on my 660 with.
