Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: '55 650 exhaust manifold
[Return to Forum]
Oaf
01-03-2013 18:09:35
108.75.43.103
Hey all, Happy New Year!!
The bronzed up exhaust/intake manifold on my "55 Ford 650 finally cracked. I ordered a new one (EAE-9425-D) and the carb holes are spread too wide. Does anyone have an idea if there is a good place to get a manifold that doesn"t require messing around with? It seems when a part is shown that fits 90000 different models, there are sure to be some glitches.
[Reply]   [No Email]
Dean
01-03-2013 18:20:41
152.216.3.5
Re: '55 650 exhaust manifold in reply to Oaf, 01-03-2013 18:09:35
All of the aftermarket manifolds are universal fit models. You will likely also find that the installled vertical positioning of the carburetor does not quite match the air tube.
Buy a good used one if you want an OEM fit.
Dean
  [Reply]  [No Email]
Oaf
01-03-2013 20:38:59
108.75.43.103
Re: '55 650 exhaust manifold in reply to Dean, 01-03-2013 18:20:41
I noticed that. The piping was thicker too, which made getting a socket on the interior impossible, so forget about using a torque wrench. There really isn"t that much meat on the interior to cut into it much. I may try a plate with studs up and screws down. More work but the vertical position will be better aligned and I won"t be chopping up the metal.
  [Reply]  [No Email]
soundguy
01-04-2013 15:24:30
173.105.197.3
Re: '55 650 exhaust manifold in reply to Oaf, 01-03-2013 20:38:59
spacer plate or slots. both work.
good luck!
  [Reply]  [No Email]
Oaf
01-04-2013 20:04:58
108.75.43.103
Re: '55 650 exhaust manifold in reply to soundguy, 01-04-2013 15:24:30
You"re right as usual soundguy. There is enough meat there to cut away to slip the nuts on, but the spacer idea doesn"t really have enough room without increasing the slots outward. Otherwise the studs to the manifold would interfere with the screws to the carb. I don"t have anything trustworthy to cut the manifold so off to the machinist they go.
It"s never as easy as you want it to be. Such is life!
  [Reply]  [No Email]
souNdguy
01-05-2013 13:19:39
173.104.253.184
Re: '55 650 exhaust manifold in reply to Oaf, 01-04-2013 20:04:58
that manifold cuts remarkably easy. a flat file will square outr some area for nuts.. and a rat tail will make slots.
a die grinder stone or bur will too. that grey iron is super soft.
one of those drill bits with the 'teeth' onthe side will do it.. that's wht I did the one on my 660 with.
  [Reply]  [No Email]
soundguy
01-03-2013 18:15:58
184.247.243.157
it's simply a universal manifold to fit the narow and wide spaced carb bolt patterns...
just file the holes into slots a lil more.
grey iron is terribly hard to drill or file.
I had to slot my 660 manifold when i changed carbs... took all of 5 minutes.
this can be an easy fix. no need to complicate it and spend more time and $$$
This post was edited by souNdguy at 18:26:49 01/03/13.
  [Reply]  [No Email]
Oaf
01-03-2013 18:14:07
108.75.43.103
It's an EAE-9425-D that I need.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
