TractorLinks.com
Show Parts for Model:
Re: 651 12 volt battery
old
01-03-2013 17:48:44
Would you believe since it is a 12 volt conversion there is NO CORRECT battery for it since it was made factory wit ha 6 volt battery. What you need is the biggest battery that will fit in the battery box with the highest CCA you can find. That is about as correct as you can ever get. But before I just took the old battery out I would #1 check the system and make sure it is working as it should as in charging as it should. With it not running the battery voltage should read around 12.3 volts on a VOM and with it running around 14 volts. If you do not get either then have the battery load tested first then the alternator.
