Yesterday's Tractor Co. Fast, Friendly Parts Service
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 960 question
[Show Entire Topic]  [Return to Forum]
Phil960
01-03-2013 17:07:57
173.30.173.190
Dean, According to the temp guage and me not noticing any steam or overflow seepage, there were no issues overheating. I did notice a small leak in the rad coil but never lost enough antifreeze to require adding any.
Soundguy, I tend to agree with you on the air flow assessment although I know it can make a huge difference in a 2 cycle engine. A completely different animal but it's part of why I asked this question.
I was very careful when putting the gaskets in for the manifold and carb as I know that can be an issue, so I'm confident there's not an issue there.
I do have a heat temp gun but had not even thought about looking for hot spots. That's a great suggestion and I will do that.
After looking at the radiator closely, I'm starting to think that's the prob. Now I just hope they can fix it.
Thanks again guys. This is my first foray into an old tractor so I'm soaking up your knowledge like a sponge. Hopefully, one day I will be able to help someone else.
[Reply]   [No Email]
Dean
01-03-2013 18:23:08
152.216.3.5
 Re: 960 question in reply to Phil960, 01-03-2013 17:07:57
Again, you symptoms point to coolant flow issues.
Normally, I would recommend inspecting the water pump impeller for wear but this cannot be your problem IF the symptoms appeared suddenly.
Dean
[Reply]  [No Email]
soundguy
01-03-2013 18:10:07
184.247.243.157
i've seen cores so plugged that they flowed only a trikle and caused fast overheating.
if your rad shop can't fix it.. see what they can source as replacement core.. get a hd core with more tubes.. ot less. I have seen some light dutry core with few tubes.. they are not as good..
The more hp you use.. the more cooling you need.
I have a 950 mutt/parts tractor with a non oem radiator from smal weird import car that I found to fit in.. it is less capacity.. I can make it boil if I work the tractor to full potential. for now I hung a carb on it for a 134ci eng to reduce the ponies and cooling needed. now I can run it to the hilt that the carb will allow and not heat... one day I'll find a good rad for it an put it's larger carb back on...
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
