| Ford Tractors Discussion Forum |
Topic: 651 12 volt battery
[Return to Forum]
| Author |
[Modern View]
| JLadd1113
01-03-2013 16:58:44
67.249.226.30
I have a 651 that my step father gave me. It has a battery in it that doesn"t hold a charge very well anymore. I could go get the same style battery, but I have the suspicion that it isn"t the right battery to crank this old gal over.It has been converted to 12 volts (along with the alternator and electronic ignitor).Thanks in advance! |
| mgriff543
01-03-2013 17:25:13
69.95.74.132
Re: 651 12 volt battery in reply to JLadd1113, 01-03-2013 16:58:44
| If the starter was left 6V, as they often are, any 12V battery should be ok. Just be careful on length of time cranking, the shorter the better. 6V starters are great when run on 12V. If the old battery works well when charged there's no need to upgrade.
Mike |
| JLadd1113
01-03-2013 17:33:46
67.249.226.30
Re: 651 12 volt battery in reply to mgriff543, 01-03-2013 17:25:13
| The battery does seem to crank it fine, it just seems to go dead quick. I try not to let it crank to long. So I should just get the same part number that is in it now? I was hoping to find the exact correct battery size that a 651 with a 12 volt system should have. As far as I know, this one could be correct, but there is no reference that I can find online on which battery it should have.Thanks again! |
| soundguy
01-03-2013 18:02:41
184.247.243.157
Re: 651 12 volt battery in reply to JLadd1113, 01-03-2013 17:33:46
| | aven a smaller car battery will work in these machines. anything bigger tan a lawn tractor battery.. etc.. is it goinf dead due to a load? or just age? if a load.. pull egative cable one night and check it.. if not going dead.. check wireing.. especially alternator #1 and #2 lines.. |
| old
01-03-2013 17:48:44
209.86.226.40
| Would you believe since it is a 12 volt conversion there is NO CORRECT battery for it since it was made factory wit ha 6 volt battery. What you need is the biggest battery that will fit in the battery box with the highest CCA you can find. That is about as correct as you can ever get. But before I just took the old battery out I would #1 check the system and make sure it is working as it should as in charging as it should. With it not running the battery voltage should read around 12.3 volts on a VOM and with it running around 14 volts. If you do not get either then have the battery load tested first then the alternator. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
