Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 5000 Parts Online
Re: Ford 5000 Piston
01-02-2013 18:17:33
If the overall volume is the same, then yes. The most important thing is deck height, which is the amount the piston protrudes above the top of the block at TDC. Anything between 0 and .010" above will use a thin head gasket, and if you're between .010" and .023" above, you want the thick gasket. If your piston does not come up to the top of the block at TDC, you have bigger issues.
Bruce Nelson
01-03-2013 07:26:46
 Re: Ford 5000 Piston in reply to Bern, 01-02-2013 18:17:33
What should a thick or a thin gasket measure? I have a gasket set, not sure if it came with a thick or thin. Thanks for the help.
01-03-2013 21:26:23
 Re: Ford 5000 Piston in reply to Bruce Nelson, 01-03-2013 07:26:46
I want to say that a thick gasket measures around .060" compressed (i.e. head torqued down), and the thin is around.040". These are approximate numbers.
