Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3500 Fuel Issue
jaluhn
01-01-2013 20:10:16
Agreed. Know where I can find a Simms pump manual? The manual set I have the Ford 3400, 3500, 4400, 4500, 5500 & 5550 reprint manual set off this site and has no info about injection pump work beyond R&R. It does have injector rebuild info. I have found a Dexta service manual that has good info on a very similar Simms pump.
For what they do, injection pump are actually pretty simple pieces of gear. There's really nothing much different in working on the injection pump and rebuilding an engine, just much finer tolerances and more adjustments. The tricky part is replacing parts and the calibration, but most of the adjustments you don't have to mess with. I've had good luck working on Bosch VE type pumps this is just by first inline.
IMHO injection systems are much less sensitive than the common perception. Look at how much people run waste motor oil and veggie oil in diesels.
I used to be scared to mess with injection systems at all, but once I finally got into them it turns out that things aren't as scary as they seem. The big issue is of course that it's very easy to make a mistake that bites you in the rear later. On the other hand, for a low use ranch tractor that doesn't get run hard you can get away with things not quite being perfect, and it's also hard to justify throwing the kind of money around to get it properly done.
RodInNS
01-01-2013 20:38:24
 Re: 3500 Fuel Issue in reply to jaluhn, 01-01-2013 20:10:16
FOrd 10/30 series manuals have the full information compliment on Minimec and CAV pumps. Specs could be a bit different tho as compared to the older generation simms pump. For all that it will probably explain most of what you need to know.
Another text... "Diesel Mechanics' should cover fuel systems fairly well in general but probably doesn't give the precise setup info you need.
I agree that the mechanics of the pump are not all that difficult. The settings are precise tho.
Rod
