| Ford Tractors Discussion Forum |
Topic: Can a loader operate on a 2N?
[Return to Forum]
| Author |
[Modern View]
| Bruce Shaver
01-01-2013 11:52:48
71.237.102.240
Can I put a loader on a 2N that will operate properly? I assume I need to put on a PTO hydrolic pump on. Is it a "live" PTO so the loader works if thr tractor isn't moving? |
[Reply] [No Email] | |
| BOB HAWBECKER
01-02-2013 18:27:34
71.173.208.237
Re: Can a loader operate on a 2N? in reply to Bruce Shaver, 01-01-2013 11:52:48
| front axle is the weak point tractor not made for loader work just tears things up steering front end and such i had one on mine 5 foot bucket and it would kill it in a hurry so my advice is too run away and dont walk. |
| Jim in Ma.
01-01-2013 16:46:18
72.70.97.191
| Since they already have a loader tractor, I'm thinking that for the best money spent - Add a carrieall to the back. That should handle those small jobs with ease. |
| Ultradog MN
01-01-2013 16:09:21
184.100.109.75
| In my opinion the 4 speed in the 8N was the most rediculous transmission ever put in a tractor. Reverse gear was so fast as to make it almost unuseable without an added step down transmission. First gear was awful fast too. The 9/2Ns only had 3 gears but it was a better tranny - if only because it had a better reverse. The 8N was a better tractor in most regards than a 9/2N - real drawbar, normal brake pedals, position control, more modern steering box and distributer on the later ones plus a few more ponies. It was that reverse gear that killed those tractors for me. |
| Royse
01-01-2013 15:19:31
69.36.49.151
| 3 speed tranny vs 4 speed on the 8N.
9N/2N left brake pedal is on the left side with the clutch pedal.
Unless they're working and adjusted perfectly its hard to use the left brake.
A tad less HP than the later model 8N, but not enough to worry about.
Now the biggie - the 8N has position control on the 3 PT hitch, meaning you
can set it where you want it and it will stay there. It also has draft mode.
The 9N/2N only have draft mode, which adjusts itself constantly and does
not stay where you put the handle.
That can be overcome by buying Zane Sherman's "thang", which effectively
adds simple, exterior bolt on (5 minute) position control.
All the N's are good tractors in my book.
The NAA is the only N with live hydraulics.
It also has the over head valve 134 CI red tiger engine.
This post was edited by Royse at 16:07:50 01/01/13. |
| Royse
01-01-2013 12:35:02
69.36.49.151
| Most loaders on an N use a front mounted stinger pump.
Pump is driven by a shaft that goes through the crank hole in the grill
and runs directly off the engine crankshaft. Thus, live power.
I totally agree with the steering issue statement.
Not to mention, the front axle of an N is light duty. They wear out
and break pretty easily under the strain of a loader.
I have a loader on a 9N, and a loader on an NAA and recently
added power steering to the NAA.
They work great for light work, but are not going to cut it for heavy work. |
| Bruce Shaver
01-01-2013 14:54:31
71.237.102.240
Re: Can a loader operate on a 2N? in reply to Royse, 01-01-2013 12:35:02
| Thanks for the info and advice. I do all of the tractor work and equipment maintenance for a ranch and equestrian facility using their JD 3020 loader tractor. The owner (a widow) wants a small tractor for the barn manager and horse trainer to use to drag the arenas. I found a nice 2N but she asked if we could put a loader on it. I'll advise her to allow me to do all of the loader work with the JD 3020, but if she wants a loader on the 2N, just use it for light work (shavings or moving some small hay bales). Any other weaknesses of a 2N verses 8N? |
| soundguy
01-01-2013 15:44:11
173.107.100.52
Re: Can a loader operate on a 2N? in reply to Bruce Shaver, 01-01-2013 14:54:31
| | yep.. decent powered wheelbarrow. ( Ps on your earlier comment about live pto... no live pto on a N.. push clutch, pto stops.. HOWEVER.. you do NOT have to be moving to have pto... in neutral, the pto will run, as long as the foor ain't on the clutch..e tc.. ) |
| old
01-01-2013 15:16:55
209.86.226.27
| If you just have to have an N series tractor go with the late 8N. The 8N has one more forward gear if you only have the factory transmission but there was a couple add on aux transmissions like the Sherman which if a combo would give it 12 forward. Also the late 8N as in May of 1950 and later had as side mount distributor which by far was a heck of a lot better and that system held up far better then the front mount distributor. The front mount has a weak coil and was known to cause problems often. I have a late 1950 8N with both loader and back hoe and it sits a lot of the time not running but most of the time it will start right up with little or no work to it |
| TimPa
01-01-2013 12:27:06
75.117.128.115
| there's two drawbacks to a loadr on an "N". the pto driven hydraulic pump only will operate when the clutch is out, and without power steering, the steering becomes very difficult when there is any load in the bucket. the n isn't a great loader tractor, but many have them |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
