Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: ford 850
old
01-01-2013 09:04:34
Run for a minute can be many things. As Ultra said check fuel flow for a few minutes catch it to look for dirt/rust/water. Good flow then check spark has to be a blue/white and jump a 1/4 inch gap or more. One common problem which you may have is a bad ignition switch and a minute is about how long one works if bad to check that run a hot wire from the ignition side of the battery to the ignition side of the coil and try it. If it runs then your problem is from the coil back to the battery.
