| Ford Tractors Discussion Forum |
Topic: 600 ran fine.. Now No
[Return to Forum]
| Author |
[Modern View]
| Dale McQueen
01-01-2013 06:45:23
208.103.46.66
1954 600 ran fine. Accedentally left key on and now nothing. I know the points & cond are touchy, so I changed everthing, pts, cond, rotor, cap & coil. Am getting 6v to coil all the way to the pts when open. Also, getting spark at pts when shorted with screw driver. Any help would be appreciated. Thanks |
| old
01-01-2013 09:00:59
209.86.226.32
Re: 600 ran fine.. Now No in reply to Dale McQueen, 01-01-2013 06:45:23
| First off what do you have?? No such thing as a 1954 600 they came out in 1955 the first year. That said you have spark at the points but do you have the points set correctly at 0.025 and did you set that on the top of the lobe?? Since you say 6 volts at the coil I am guessing it is still a 6 volt system. You also said you got new parts. You may have your self a bad new condenser which is common now days. Pull the center wire out of the cap and hold it about a 1/4 inch from the block and spin it over wit the ignition on. You should see a blue/white spark that jumps a 1/4 inch or more. No or weak spark go back and check your points and make sure there is not short etc in that area |
| Ultradog MN
01-01-2013 07:20:21
184.100.109.75
| First make sure you have spark at the plugs. Pull a plug wire and ground it to the engine block somewhere. You should have bright bluish white spark that will jump a good 5/16" If you have good spark and if you have been turning it over a lot you may have your engine flooded. Take the plugs out and let the cylinders air out a bit. Bring the plugs in and cook them off over the stove or use a propane torch. Then reinstall them and try it again. Post back with your results. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
