engine driven pump 4610
hurleyjd
Has Anyone installed the cam driven pump on a 4610 to run the front end loader, and is it faster than the gear driven pump in the rear end.
As I recall (I'm going off memory here), the two pumps have roughly the same GPM, so adding the engine pump should roughly double your loader speed.
The cam driven pump is about 75% of the transmission pump, but the flow is in addition to, not instead of! That said, it's an expensive add-on, especially if the gear to drive the pump is not already in place!
I had the second pump added to my 5610, and it made the lift on the discbine much better! Fortunately, both my 3910 & 5610-2 came with double pumps! Both have loaders, and both have acceptable flow for loader work.
JMHO, HTH, Dave
