TractorLinks.com
Order Ford 600 Parts Online
Re: Ford 600 transmission swap
RBnSC
12-31-2012 08:52:17
Will bolt right in.Sherman won't work. Get the flywheel bolts and trans to pinion coupler. Be sure that it is an 860 trans. Be sure to take the pto side cover off before you remove the trans. And prepare to clean out the hydraulic reservoir as they are usually full of gunk. Did 8XX and a 6x1
in the last few weeks.
Ron
fuelie74
01-01-2013 13:35:26
 Re: Ford 600 transmission swap in reply to RBnSC, 12-31-2012 08:52:17
I picked it up today. I think I got everything I need except for the flywheel bolts. They weren't sure what they did with them. Are they different than the bolts holding my flywheel on?
The transmission case also has some striped threads and some big gouges out of the area where one of the front axle radius rods attach. Any suggestion on repairing this? Is it a common problem?
RBnSC
01-01-2013 16:04:07
 Re: Ford 600 transmission swap in reply to fuelie74, 01-01-2013 13:35:26
The bolts are shorter than the ones in a nonlpto flywheel. The bolt holes have to be dealt with as they go through into the transmission housing. The gouges I don't think Would hurt as long the housing is not cracked. Ron
fuelie74
01-01-2013 19:41:25
 Re: Ford 600 transmission swap in reply to RBnSC, 01-01-2013 16:04:07
Anyone have the specs on the flywheel bolts so I can find some replacements?
