Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 960 Parts Online
Re: 960 overheating
Phil960
12-31-2012 07:27:42
Thanks Guys, I appreciate your help. I guess I just don't understand what happened. It had been running fine and all of a sudden it's not. It seems that the common sense approach would be the stat since they are either open or closed. The water pump/ fan belt is adjusted to about a 1/2 inch deflection and in decent shape. The fan shroud is in place. I'll keep investigating. For me this is the fun part, working on the old girl.
old
12-31-2012 11:19:17
 Re: 960 overheating in reply to Phil960, 12-31-2012 07:27:42
A thermostat can be just fine today and tomorrow just plain and simple not open due to being stuck. I would do the water pan test to start with then go from there. Never good to throw parts at a problem till you know what the problems is. Your system may just need a good old vinegar flush for that matter but that is a bit harder to do this time of year due to vinegar will freeze
Dean
12-31-2012 07:50:54
Did you change ANYTHING prior to the new over hearing problem?
Do you live in a cold climate? If so, might the coolant have slushed?
Is the bottom radiator hose old and soft? If so, it might be collapsing.
All indications point to coolant circulation issues.
Dean
