Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Ford 641 been sitting over 1 year, No Oil Pressure
12-31-2012 07:18:43
My experience, for what it is worth, is that the oil gauge line is removable with the right sized open end wrench; you can prime the pump with your drill and 14 inch bar/rod stock as Kurtnepa suggested; You can make your own hex end onto a square bar on a grinding wheel if you can't find hex; you should not plan to reuse the O-rings on the manifold, in fact you should go to CNH to get the exact right ones. If you try running the pump with your drill, the camshaft allows oil up to the rockers only when in the right position in the rotation so you will need to turn the motor a little by bumping the starter or with wrench on the front nut.
