TractorLinks.com
Show Parts for Model:
Re: Generator Output Test
JMOR
12-30-2012 14:12:47
Quoting Removed, click Modern View to seeTom, your clamp on DC ammeter would still be just fine. It is the Armature to Field jumper that commands full output.
Tom Bond
12-30-2012 18:00:39
 Re: Generator Output Test in reply to JMOR, 12-30-2012 14:12:47
Just want to be sure before I try. Leave all connections wired "as is" and then jumper the armature and field terminals on generator to command for full load? Then use my DC clamp on red armature wire to measure current going to voltage regulator? Will also check voltage going to battery when running as mentioned in previous reply.
JMOR
12-30-2012 18:03:47
 Re: Generator Output Test in reply to Tom Bond, 12-30-2012 18:00:39
Quoting Removed, click Modern View to seeyou got it right.
Tom Bond
12-30-2012 18:00:17
soundguy
12-31-2012 15:08:46
 Re: Generator Output Test in reply to Tom Bond, 12-30-2012 18:00:17
full field her and check amps and volts...
