Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Noise in my SOS
[Show Entire Topic]  [Return to Forum]
TONY JACOBS
12-29-2012 16:41:46
64.12.116.9
Hello Hunter , Sounds to me as if the Main Shaft bearings are going south , a common problem when 5000's with SOS's get high hours on them . There are three bearings on the main shaft when they get REAL BAD they will take out the oil pump then of course the rest of the trans will be full of metal from the destruction . Time to fix it is NOW before it gets to the destruction stage because it will double the cost when it blows . I have done a few 5000's both before and after so I have seen the mess first hand. Thanks Tony
[Reply]   [No Email]
Greg NE
12-29-2012 19:22:19
75.230.66.4
 Re: Noise in my SOS in reply to TONY JACOBS, 12-29-2012 16:41:46
Tony, you jogged my memory alittle with your post and now I remember Dad had those replaced once a long time ago when I was a kid. It also might explain the low preasure in it now as it got alot of use after and had the clutch packs replaced too. I still have that tractor and dream of fixing it up again someday when the funds allow. That tractor could sure pull a 4-14 plow, only problem was traction even with fluid and 3 weights on each side. It sure would put a buddy of mine and his 656 farmall to shame at a plow day. ;^) Greg NE
[Reply]  [No Email]
TONY JACOBS
12-30-2012 07:12:26
205.188.116.9
 Re: Noise in my SOS in reply to Greg NE, 12-29-2012 19:22:19
Hello Greg , I am sure your Dad had them done a couple of times if you guys had upwards of 20,000 hours on it unless he replaced the trans. at one time . I also run an extra gallon or so of oil in them so the splash is heavier and lubes them better . I run extra oil in all of my SOS's too the 801/4000's will cavitate on a steep side hill when I was pulling logs with them finally stopped it with an extra gallon in them . Thanks Tony
[Reply]  [No Email]
Greg NE
12-30-2012 20:19:29
75.254.137.143
 Re: Noise in my SOS in reply to TONY JACOBS, 12-30-2012 07:12:26
Tony, where do you put the extra oil in at on a 5000, no cover to pore it in? I haven't looked at this tractor in a long time but only remember the pain in the butt level plug on the side like my 63 4000 and 59 971. I just wish I knew 1/8th as much about these trannys as you do as I really like them. Picked up my 971 this summer from an older farmer that parked it when it quit moving, sure enough it was the imput shaft splines and thanks to the folks like you on this board I knew about the trick to stand the rearend on end to keep washer from falling out. Was out tooling around with it about three hours later the same day and it works great. I did make me up an adapter to run tranny with a drill first to check the oil preasures at the three ports to see if it was worth taking a chance on. Didn't need another tractor but you know how that goes, price was right and wanted to save another sos. thanks Greg NE
[Reply]  [No Email]
RodInNS
12-29-2012 17:05:11
216.118.158.123
My thought was also the input shaft based on the description... but I guess that would depend on how bad the noise is or one's perception of it. The description of the problem initially does suggest input tho.
Rod
[Reply]  [No Email]
TONY JACOBS
12-30-2012 07:16:37
205.188.116.9
 Re: Noise in my SOS in reply to RodInNS, 12-29-2012 17:05:11
Hello Rod , The problem now is if you let them go to long and it destroys to much it gets way to expensive to fix them because the parts are getting harder to find , bearings are pricey enough never mind wiping out the pump and shafts too. Thanks Tony
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
