TractorLinks.com
Order Ford 2000 Parts Online
Re: Ford 2000 Selenoid
RodInNS
12-29-2012 13:17:49
Basically... all you do with those things is make sure that all of the connections are clean on the solenoid and the starter motor and make sure you have known good cables.
What I often do is drop the starter on the ground and hook it to a set of booster cables... then jump across the terminals while you hold the starter down with your foot. See if it works. If it doesn't work try hooking the pos cable directly to the starter motor terminal and see if the starter spins up. If it does... you've likely got a bad solenoid. More like bad internal contacts in it.
If you're real adventerous you can melt the solder off the terminals on the cap and take the switch apart, clean the terminals and put it back together. Otherwise you buy a new switch.
Rod
old
12-29-2012 13:47:36
 Re: Ford 2000 Selenoid in reply to RodInNS, 12-29-2012 13:17:49
Drop the starter. That is hard on the starter and hard on the toes. LOL I think I would say I set the starer in the ground since some might just do as you said and end up with a broken starter.
RodInNS
12-29-2012 14:31:23
 Re: Ford 2000 Selenoid in reply to old, 12-29-2012 13:47:36
As long as he doesn't drop it on the switch it won't hurt the Lucas... but yes... set it on the ground.
Rod
