Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Need tips for changing PTO lever seal
[Show Entire Topic]  [Return to Forum]
Laneman
12-28-2012 16:17:05
199.115.190.204
Well the job is done. Read below for how to info and avoid my mistakes. This is for an 8 speed 3000. Remove left footrest. Drain the rear axle to just below the PTO lever cover, about 3 gallons should do. I believe the manual says to engage the PTO lever (move to rear), then remove cover bolts, paying attention to different bolt sizes. There is a clutch pedal spring and bracket you'll have to fiddle with, not too hard. I put a drain pan under my cover. Remove cover with lever straight out, making sure shift fork doesn't slide off and fall into the sump. Note where a check ball sits under the back side of the lever and be sure you put the lever back so the ball is in the same hole. As you remove the cotter and roll pin to pull the lever off, make sure the ball doesn't go flying out or you'll lose the ball. Ask me how I know. After I got back from the dealership with my new check ball, gasket and o-ring, I put the check ball back on the spring and put the lever so the ball was in the same hole I started with. I advise working inside a box with the assembly as it's very easy for the ball to fly out. Squeeze the assembly together, oil up your new oring and put it on the outside of the shaft,press oring down into the groove, then hold shaft on with a temporary bolt. Now drive the roll pin back in and put in a cotter pin. Put gasket onto cover, orient shift fork with curved side down, and slip cover back on. If you have lever/check ball in its original position the shift fork should slip right into the gear slot. Start the top bolt, then fiddle with the bracket and clutch spring to get other bolts hand tight. Now check that PTO lever moves ok, engage it and make sure PTO shaft locks up and frees up with lever position. Now torque all bolts to spec, top off oil, run lift up and down a few times. A final note, if you're only changing the oring, you may be able to leave the cover on and dig out the oring after sliding off the lever, but I don't know if the lever will push back on without the shaft falling into sump.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
