| Ford Tractors Discussion Forum |
Topic: Re: High houred 8970
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| jbirnsch
12-27-2012 19:25:02
50.116.153.97
So now I'm worried :(What are good numbers for flow and pressure on the remotes? I have a pressure gauge for testing remotes. How does one get the hydraulics hot on a dealer lot. Our farm is 100 miles away from the dealer. What about the 3 point? Are the mag plugs seperate from the drain plugs? On the other fords we have they are integrated. Do I demand them to be drained and checked? I don't want to be a PIA but I don't want to be taken either. Should I get ahold of the previous owner as the dealer has his number. I was wondering about the brakes taking out the power shift. Dealer stated the brake disks were warped and the reason they were replaced. Warped means it got hot to me. Can ECU data be pulled and reviewed? |
| Bern
12-27-2012 22:06:15
66.218.203.146
Re: High houred 8970 in reply to jbirnsch, 12-27-2012 19:25:02
| | You can't test flow using a pressure gauge only, but I'm sure you know that. Best way to get the oil hot is to bring along a jumper hose and loop it into two couplers of the same valve. Flow oil through this hose. Then deadhead another remote. This should force the pump to pump full flow and full pressure. This assumes the tractor is not MegaFlow. If it is MegaFlow, do this test using remotes # 1 and 2, or 3 and 4. Do this until the filter gets hot to the touch. That should be good enough. I believe that standby pressure on those rigs was around 2750. Without a flowmeter though, you have no good way to test pump performance. Not sure on the drain plugs. If it were me, I'd drain the oil and pull and check the suction screen. It's been years since I've looked at codes on those things. I'm not sure whether overheat codes are permanently stored or if they're lost on a battery disconnect. Wouldn't hurt to have the dealer plug in and take a look if he has the tool. Absent the tool, a lot of info can be gleaned from the dash cluster, if you have a manual nearby to interpret the numbers. |
| RodInNS
12-27-2012 20:12:57
216.118.158.123
| If the brakes got hot and warped... they crapped their linings into the oil. Then you have a plain pure nightmare to clean all of the crap from the system, particularly the hydraulics. If it was operated that way for any period of time (and it probably was)... I doubt the hydraulics will ever be the same. I'm trying to remember the specs on them. IIRC, a standard single pump system should make 34GPM @ 2750 psi and that might take a couple of remotes to flow that much. Mega's should make 55 gpm at 2750 psi.... and I mean maintain that pressure at full flow.... not just deadhead a guage to 2750 or make rated flow at no pressure.I would expect the mag plugs to be either drain or drain/level plugs on the planetaries. At this point in time I'd demand to talk to the previous owner AND drain the oil... because the previous owner probably didn't disclose whatever ails it so dealer may legitimately not know.... Rod |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
