TractorLinks.com
Order Ford 661 Parts Online
Re: 6610 tach cable
RodInNS
12-26-2012 20:29:16
I can't imagine why you'd pull the sheet metal OR the dash for this job if in fact it's only the drive that's broken.
What you do... remove the oil filter, then the bolt in the top of the drive (loosen) the work the drive out of the engine. When you get that out, pull the drive gear out and fish the broken pieces of the cable from the center of that... reinstall in reverse of removal. Just make sure you get the new cable properly placed in the drive gear before you bolt it all down solid.
Rod
Bern
12-26-2012 21:31:12
 Re: 6610 tach cable in reply to RodInNS, 12-26-2012 20:29:16
Rod,
It has generally been my experience that when the short cable breaks, it's because the longer one is binding up. I usually replace both when the shorter one is broken.
RodInNS
12-27-2012 06:19:31
 Re: 6610 tach cable in reply to Bern, 12-26-2012 21:31:12
Sometimes... I also find that the routing of the longer one is quite frequently responsible for the breakage... particularly around the hydraulic pump on the 30 series tractors. Too much kink and the drive breaks.
Rod
Bern
12-27-2012 06:45:01
 Re: 6610 tach cable in reply to RodInNS, 12-27-2012 06:19:31
Yep, agree also on the misrouting and too much kink. One wants to install the tach cable with as gentle a bend as possible.
Brian in MA
12-27-2012 12:23:06
 Re: 6610 tach cable in reply to Bern, 12-27-2012 06:45:01
I also have experience shutting it in the hood and kinking it that way, which lead to a broken cable also. I couldn't understand why it was so hard to latch the hood, but that didn't stop me from doing it :-)
