871 rear axle
Got the axle sitting on bench with backing plate and all. How much slop would you allow just pushing backing plate side to side between coller and bearing retainer. I got 1/16 space to when pushing backing plate down on one side short 1/16th. Thanks, Dave
That's not a measurement that's important or even looked at. What IS important is the axle shaft preload as measured when the axle assembly is installed in the tractor.
