TractorLinks.com
Order Ford NAA Parts Online
Re: Jubilee 3 pt lifting problem
Kurt-NEPA
12-26-2012 13:26:31
It could be a number of things. When you say "It won't lift until the tractor runs for a few minutes" it sounds like a "Loss of Prime" issue. When you say "It only lifts in the last 2 inches or so of moving the lift handle" it sound like the cam follower pin is worn or the the linkage is out of adjustment.
Do you have the early square vane pump or the later round piston pump? If you have the later pump, the seal and shaft are replaceable and there is a good test to confirm a suction side leak (ie wobble shaft seal).
old
12-26-2012 14:57:54
 Re: Jubilee 3 pt lifting problem in reply to Kurt-NEPA, 12-26-2012 13:26:31
Guess you missed it he said he has the vane pump which can be a problem in them self's
